Sysinternals Antivirus Manual Removal instructions
Sysinternals Antivirus is a rogue anti-spyware application that has been directly related to Your PC Protector. Just like the program it is related to, it tries to trick users into paying for a software license. This rogue application gets installed via Trojans that force their way on to the user system through malicious websites. Once installed, Sysinternals Antivirus loads itself as a startup service and proceeds to perform endless scans of the user=92s system, handing out fake reports which try to convince the user that the computer is dangerously infected with a number of malware applications. Sysinternals Antivirus also displays a large number of fake warning pop-ups from the Windows taskbar in an attempt to scare users. The aim of all this activity is to push the user into purchasing a license for the so-called =91full=92 version of Sysinternals Antivirus by claiming that the currently installed =91trial=92 version is incapable of cleaning out all the detected =91threats=92. However, it should be kept in mind at all times that Sysinternals Antivirus is simply a fake application that cannot scan or clean your computer under any circumstances. see the manual removal instructions within the link below to get rid of Sysinternals antivirus VIRUS
