Hi
I am trying to Log in to my Win 2000 from WinXP at work;
I installed that s/w (there was a sw called MSRDPCLI.EXE to enable Windows2000 to act as a client) on my Win2000 - is there anything I need to do on the Win2000?
Are there any Tutorial step by step guide?
I also have Cable/DSL router - I have set it up to port forward - is there any setting on the Host & client?
I use Fixed IP.
When I try to setup IIS on WInXP, its asking for the XP CD - its a work pc & I don't have it.
Pls advice, Thanks
