In article , wrote: :Regarding "NETGEAR FVS318 prosafe doesn't support" I checked my NETGEAR FVS318 :prosafe setting
.... just as I suggested you do several days ago...
:then I found that there is one option is given in LAN :IP setting option is given "UpnP Enable". :I think It will support so they have given. Can u tell me more about :that option means hoe this option internally work?????????????
Sorry, no. The product data sheet and reference manual for the FVS318 both omit mention of UPnP, so I cannot make any extrapolations about the extent of support for UPnP on whatever software release you are using.
For a better idea of how UPnP interacts with NETGEAR products, see the microsoft URL I posted earlier, about configuring UPnP on the NETGEAR MR router.
:Regarding "single branch office invoved" actually in vedio confrencing :at a one time three or more than three confrencing is going on. I think :u want to ask this with me actually this statemet is not clear to me.
Okay, so you have 3 or more video conferences going at a time. Where are the participants located? You earlier answered NO when I asked if there multiple branch offices involved, so do we understand correctly that there might be more than one person at the branch office and more than one person at HQ taking part in the same video conference? Or are video conferences all independant, involving pairs of people, one in the branch office and one at HQ but with several such pairs happening to communicate simultaneously ?
:Regardind Netgear configuration you told me that if my head quater has :static ip address and my branch office has dyanimic ip address then I :have to start configuration from the head office side.
No, I said that in that situation, if the VPN link is not active, and the VPN link must be started up, then either the branch must start the link, or else you have to use Netgear's support for dynamic DNS.
:Can u tell me if :I want to configure from the branch office side then what i have to :do?????
I suggest you read the Netgear FVS318 manual, as it shows how to configure VPNs. See
and make sure that you refer to the manual that is specific to your FVS318 version (there are three different hardware versions.)
