problems using different different FTP port with windows firewall
Threaded View
Hi all.  It would be fab if you could help me please!
I need to run 2 ftp sites on the same server (windows server 2003).
I've got the first one using port 21, but need the second ftp site to
use a different port I think (unless there's a way to get 2 ftp sites
working on port 21?  binding?).
so, for my second ftp site I am using port 8001.  it works ok with my
ftp client with the windows firewall off, but when I turn it on and
add port 8001 to it my ftp client doesn't want to connect any more.
I've noticed that my ftp client is actually connecting using port 8001
but then switches to an arbiutary port number afterwards when
finishing the connection.  This port number changes each time, so it's
impossible to add it to the windows firewall!  I think this is the
problem. the windows firewall doesn't support port ranges either (to
my knowledge?) so even if I knew a range I couldn't add it to the
firewall.
Any help anyone could offer would be greatly appreciated.  Many thanks
Paul
Re: problems using different different FTP port with windows firewall
In message
Which FTP client?  I had to make changes to mine when I moved to a
different firewall suite
Mike News
This probably is because the NAT helper of your firewall does not watch
port 8001 for FTP control channel traffic.
Better avoid FTP BTW. There is SFTP.
Yours,
VB.
The file name of an indirect node file is the string "iNode" immediately
followed by the link reference converted to decimal text, with no leading
zeroes. For example, an indirect node file with link reference 123 would
have the name "iNode123". - HFS Plus Volume Format, MacOS X
Site Timeline
