Problem with HTTPS through PIX for OWA
Threaded View
I am trying to configure one of our customer'sPIX firewall's to allow
SSL OWA (they are currently using http, not https).  For some reason
the commands we have added to other customers PIX firewalls aren't
working to accomplish this.
I know the first thing you will all suggest is going to be to upgrade
the IOS (we are on version 6.3(1)), but this is not an option at this
point.  We can only make configuration changes on this PIX that won't
interfere with anything else or could break anything.
Does anyone know what changes I can make to this PIX to allow SSL OWA
traffic?  By the way, ssl is working internally.
Here is the current config:
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 auto
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password vAzMma1Gux3.wkTP encrypted
passwd lwJM7e5kzPHBQwNf encrypted
hostname TSPIX
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
no fixup protocol smtp 25
fixup protocol sqlnet 1521
names
access-list bypassingnat permit ip 192.168.1.0 255.255.255.0
192.168.10.0 255.25
5.255.0
192.168.6.0 255.255
.255.0
access-list KirkResidence permit ip 192.168.1.0 255.255.255.0
192.168.10.0 255.2
55.255.0
pager lines 24
logging on
logging trap notifications
logging history notifications
logging facility 0
logging host inside 192.168.1.13
mtu outside 1500
mtu inside 1500
ip address outside xx.xx.xx.34 255.255.255.240
ip address inside 192.168.1.5 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
ip local pool clientpool 192.168.6.210-192.168.6.220
pdm history enable
arp timeout 14400
global (outside) 1 xx.xx.xx.43
nat (inside) 0 access-list bypassingnat
nat (inside) 1 172.16.100.0 255.255.255.0 0 0
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
static (inside,outside) tcp xx.xx.xx.35smtp 192.168.1.19 smtp netmask
255.255.
255.255 0 0
static (inside,outside) tcp xx.xx.xx.35https 192.168.1.19 https netmask
255.25
5.255.255 0 0
static (inside,outside) tcp xx.xx.xx.35www 192.168.1.19 www netmask
255.255.2
55.255 0 0
static (inside,outside) tcp xx.xx.xx.35domain 192.168.1.19 domain
netmask 255
.255.255.255 0 0
static (inside,outside) xx.xx.xx.37 192.168.1.20 netmask
255.255.255.255 0 0
static (inside,outside) xx.xx.xx.45 192.168.1.84 netmask
255.255.255.255 0 0
static (inside,outside) xx.xx.xx.39 172.16.100.25 netmask
255.255.255.255 0 0
static (inside,outside) xx.xx.xx.46 172.16.100.30 netmask
255.255.255.255 0 0
static (inside,outside) xx.xx.xx.40 172.16.100.34 netmask
255.255.255.255 0 0
conduit permit tcp any eq 8060 host yy.yy.yy.11
conduit permit tcp any eq 9000 host yy.yy.yy.33
conduit permit tcp any eq 1040 host yy.yy.yy.61
conduit permit tcp host xx.xx.xx.35eq smtp any
conduit permit tcp host xx.xx.xx.35eq www any
conduit permit tcp host xx.xx.xx.35eq https any
conduit permit ip host xx.xx.xx.45 host 66.207.66.14
conduit permit icmp any any echo-reply
conduit permit tcp host xx.xx.xx.40 eq citrix-ica any
conduit permit udp host xx.xx.xx.40 eq 1604 any
conduit permit tcp host xx.xx.xx.35 eq domain any
route outside 0.0.0.0 0.0.0.0 xx.xx.xx.33 1
route inside 172.16.100.0 255.255.255.0 192.168.1.1 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
no floodguard enable
sysopt connection permit-ipsec
crypto ipsec transform-set myset esp-des esp-md5-hmac
crypto dynamic-map dynmap 30 set transform-set myset
crypto map newmap 20 ipsec-isakmp
crypto map newmap 20 match address KirkResidence
crypto map newmap 20 set peer xx.xx.xx.50
crypto map newmap 20 set transform-set myset
crypto map newmap 30 ipsec-isakmp dynamic dynmap
crypto map newmap interface outside
isakmp enable outside
isakmp key ******** address xx.xx.xx.50 netmask 255.255.255.255
isakmp identity address
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption des
isakmp policy 10 hash md5
isakmp policy 10 group 1
isakmp policy 10 lifetime 14400
isakmp policy 15 authentication pre-share
isakmp policy 15 encryption des
isakmp policy 15 hash md5
isakmp policy 15 group 2
isakmp policy 15 lifetime 14400
Re: Problem with HTTPS through PIX for OWA
For future reference: PIX does not use IOS; it uses an operating system
called Finesse, but more commonly known as "PIX OS".
And yes, I would recommend upgrading to 6.3(6) as soon as that becomes
available.
Ah, well, you are trying to use conduits, anything can happen.
cisco converted to access-list / access-group in PIX 5.0(1) .
There was a big rewrite of PIX internals for 6.1, and Cisco
"Won't Fix" any 6.2 or later conduit bug unless it is a major repeatable
crash. I don't believe in trying to debug any 6.x configuration that
uses conduits
Put the group 2 before (lower policy number) the group 1 so that
it will be chosen first if the other side supports it. You want
to have the highest available security negotiated.
Walter thanks for your replay!
I got permission to replace conduit commands with ACL. I'm still not
able to access OWA through SSL.
And this is my configuration now:
hostname TSPIX
names
192.168.10.0 255.25
5.255.0
192.168.6.0 255.255
.255.0
192.168.10.0 255.2
55.255.0
access-list out_in permit tcp any any eq smtp
access-list out_in permit tcp any any eq domain
access-list out_in permit tcp any any eq https
access-list out_in permit tcp any any eq www
access-list out_in permit tcp host xxx.yy.97.40 any eq citrix-ica
access-list out_in permit udp host xxx.yy.97.40 any eq 1604
access-list out_in permit tcp any host zz.yy.176.11 eq 8060
access-list out_in permit tcp any host zz.yy.176.33 eq 9000
access-list out_in permit tcp any host zz.yy.176.61 eq 1040
access-list out_in permit tcp any host zz.yy.178.2 eq 1007
access-list out_in permit tcp any host zz.yy.178.2 eq 2007
access-list out_in permit tcp host xxx.yy.97.45 host 66.207.66.14
pager lines 24
logging on
logging facility 0
mtu outside 1500
mtu inside 1500
ip address outside xxx.yy.97.34 255.255.255.240
pdm history enable
arp timeout 14400
global (outside) 1 xxx.yy.97.43
static (inside,outside) tcp xxx.yy.97.35 www 192.168.1.19 www netmask
255.255.2
55.255 0 0
static (inside,outside) tcp xxx.yy.97.35 smtp 192.168.1.19 smtp netmask
255.255
.255.255 0 0
static (inside,outside) tcp xxx.yy.97.35 domain 192.168.1.19 domain
netmask 255
.255.255.255 0 0
static (inside,outside) udp xxx.yy.97.35 domain 192.168.1.19 domain
netmask 255
.255.255.255 0 0
static (inside,outside) tcp xxx.yy.97.35 https 192.168.1.19 https
netmask 255.2
55.255.255 0 0
static (inside,outside) xxx.yy.97.37 192.168.1.20 netmask
255.255.255.255 0 0
static (inside,outside) xxx.yy.97.45 192.168.1.84 netmask
255.255.255.255 0 0
static (inside,outside) xxx.yy.97.39 172.16.100.25 netmask
255.255.255.255 0 0
static (inside,outside) xxx.yy.97.46 172.16.100.30 netmask
255.255.255.255 0 0
static (inside,outside) xxx.yy.97.40 172.16.100.34 netmask
255.255.255.255 0 0
access-group out_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.yy.97.33 1
1:00:00
Site Timeline
