Hi!
I'm trying to set up routing on my local LAN.
Ok, the situation as now is:
comp A: Using winroute firewall 6. connected to local LAN and a wifi network. Also using rasppoe through wifi to access internet.
comp B: connected to local LAN and using dial-up for internet.
comp C,D,E: connected to local LAN
I'd like all comps to be able to access the wifi net and also use the pppoe for internet access. Also I need to be able to sometimes use the dial-up instead of pppoe on comp B.
I also want to bind multiple IP addresses on the wifi card (one for each local client).
Now, how would I go about building rules for winroute to do all that?
Comp A,B, using w2k, others mostly XP and 9x... All static IP's, except for dial-up.
TIA!
