I've got a PIX 515 that has recently started reloading itself for apparently no reason. At time it was running 6.3(3) and I have since upgraded it to 6.3(4). It is operating standalone. I had the console connected while it reloaded and there was absolutely no error messages of any description. The only odd thing that I notice about the box is that there is a red light coming from what appears to be an LED labelled "CR1" located on the main board. next to the battery. I do not recall that it was like that before... but can't be sure.
Following is the "show ver" from the PIX.. could someone help and provide some hints as to why the box might be reloading by itself? btw, the fan is operating normally.
many thanks, Lei
PIX(config)# show ver
Cisco PIX Firewall Version 6.3(4) Cisco PIX Device Manager Version 3.0(1)
Compiled on Fri 02-Jul-04 00:07 by morlee
PIX up 24 mins 44 secs
Hardware: PIX-515, 64 MB RAM, CPU Pentium 200 MHz Flash i28F640J5 @ 0x300, 16MB BIOS Flash AT29C257 @ 0xfffd8000, 32KB
0: ethernet0: address is 0050.54ff.2039, irq 10
1: ethernet1: address is 0050.54ff.203a, irq 7
2: ethernet2: address is 00e0.b604.eda7, irq 9
3: ethernet3: address is 00e0.b604.eda6, irq 9
4: ethernet4: address is 00e0.b604.eda5, irq 9
5: ethernet5: address is 00e0.b604.eda4, irq 9 Licensed Features: Failover: Enabled VPN-DES: Enabled VPN-3DES-AES: Disabled Maximum Physical Interfaces: 6 Maximum Interfaces: 10 Cut-through Proxy: Enabled Guards: Enabled URL-filtering: Enabled Inside Hosts: Unlimited Throughput: Unlimited IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
