PC Cleaning Procedures & Detection Tools
The first step in ridding your system of unwanted intruders is to protect it from them in the first place.
Reminder ? If your system is simply too infested to effectively clean, or has too many problems related to past infestations or other problems, it may be better to back up all your data, format and install Windows again, so you can have a fresh, clean start.
In order to view some of the files and folders mentioned here, you will need to set your system up accordingly. Open Windows Explorer, go to Tools, and in Folder Options, select Show hidden files and folders, and uncheck Hide protected operating system fileS.
You may also need to boot into Safe Mode, the most common way to do this is to reboot your computer, and then repeatedly hit F8 while it's booting up. A menu will be displayed which will give you several options. Select Safe Mode, and press Enter.
Another way to get into Safe Mode is to go to Start, Run, type in msconfig, and then click OK. When the System Configuration Utility window comes up, click the BOOT.INI tab, select SAFEBOOT, and then OK. You will be asked to reboot, and when you do, your system will come up in Safe Mode. When you're finished in Safe Mode, go back to msconfig and remove the checkmark from SAFEBOOT.
A combination of the utilities listed may be required to successfully clean a heavily infested system; if the ones you are using don?t seem to be doing the job, try some of the others. You should also try running them from Safe Mode.
In order to effectively clean your PC:
1.) Follow all the instructions in the Temporary Files section. 2.) Empty the Prefetch folder as explained. 3.) From the Malware section, run both Ad-Aware and Spybot. 4.) Also from the Malware section, run either CounterSpy or Ewido (or both if you like). 5.) In the Free Online Scans section, run at least two of the suggested scans. 6.) If you are still experiencing problems after taking these steps, please go to the thread concerning specific infections.
Temporary Files
Depending on your Operating System, you may, or may not, have all of the folders listed. Please complete the instructions for the ones you do have.
Delete the entire contents of your C:\\Windows\\Temp folder.
Delete the entire contents of your C:\\Temp folder.
Do a search for *.tmp and delete all entries found.
For every User listed under C:\\Documents and Settings, delete the entire contents of these folders (not the folders themselves): Local Settings\\Temp Cookies History Local Settings\\Temporary Internet Files\\Content.IE5
If you have Firefox, open it and go to Tools, Options, and then click on Privacy (padlock icon on the left); click on the Clear All button.
If you use any other browser, clear the History, Cookies, and Cache.
Go to Start, Run, type in cleanmgr, and then click OK. Select the drive your operating system is on (usually C), and check the boxes for Downloaded Program Files (move any files you wish to keep out of this folder first), Temporary Internet Files, Recycle Bin, Temporary Files, Temporary Offline Files, Offline Files, (and Compress old files & Catalog files for the Content Indexer if you wish), and then click OK. Click Yes to confirm you want these files deleted. It may take awhile for this to run, please be patient.
Note: if any of these temporary files cannot be deleted while in normal mode, try Safe Mode. If any still cannot be deleted, use the Pocket Killbox (link below). Please ask for instructions before using this tool!
Prefetch
To increase the startup time of your applications, Windows pre-loads portions of programs in a folder called Prefetch. Malware sometimes imbeds itself in this folder and uses that as their ?autostart? mechanism each time you boot.
Since Windows will automatically repopulate the Prefetch folder with valid program entries, emptying the entire contents of the folder won?t do any harm. You can do this by going to C:\\Windows\\Prefetch; open the Prefetch folder, click on Edit, Select All, and then hit the Delete key.
Utility to help with cleanup:
CCleaner ? Removes unused and temporary files from your system.
Malware
There are several free (or free-to-try) utilities available to help rid your system of unwanted intruders. Always be sure you have the latest versions and update them immediately before scanning. Also, go through their configuration options and make sure they are set to properly scan your system. If you have any questions about these settings, feel free to ask us.
Must have these:
Ad-Aware SE Personal Edition ? Removes ad-supported software components from your system.
Spybot - Search & Destroy ? Removes threats to your security and privacy from your hard disk and Registry.
Pocket Killbox ? Use to delete files that refuse to be deleted normally.
Should have at least one of theses:
CounterSpy ? Detects and deletes malicious software from your PC.
Ewido (XP users only) ? Protects your computer from various threats and hackers.
Other helpful utilities:
Stinger ? Scans data for viruses and objectionable content.
TrojanHunter ? Examines your files, registry, open ports and running processes to protect against Trojans.
Trojan Remover ? Aids in the removal of Trojan Horses and Worms.
Free Online Scans
dr.nil
If you have Drive Image 7 and you delete the contents of the C:\\Windows\\Temp folder. You will break it. Drive layout information is stored in two files in this folder.
Smiley Burns
I'm sorry, but what freakin' idiot decided that was a good idea. Does this person not speak or at least vaguely understand English? Does this person not realize the 'Temp' stands for "TEMPORARY"?
temporary adj. for a short time only; lasting, used or enjoyed for a limited time; not permanent
Sheesh!
Old guy
Moe Trin
I'm sorry, I just retested the effect of moving those two files to another location and ran a backup with no problem. I had tested it twice before and it wouldn't even load properly. Now moving those files seems have no effect at all. Sorry about the misinformation I posted.
Smiley Burns
The IEEE's POSIX requirements identify temporary directories (/tmp/ in UNIX) as a place for temporary storage, but with the proviso that the application creating these files must not expect the files to last longer than it does. The original concept was that /tmp was used as a momentary holding point - where you ran one application and got some intermediate data that was going to be used in another application - perhaps you used a database tool to locate all of a model car you wanted to purchase - and you would then plug this small data set (rather than the whole database) into a spreadsheet to figure out which you can afford. The intermediate data need only exist until it can be plugged into the next part of the task.
While microsoft likes to claim that somehow, windoze is POSIX compliant, they're rather lax at enforcing the concepts. In many implementations of UNIX, /tmp/ gets cleared at boot time (not a big deal, we don't reboot that often), and an automatic (cron) job will delete files in /tmp/ that haven't been used in some period (like a week). You wouldn't believe the screams we hear from new users who stashed something in temp because it seemed like a good place at the time.
Old guy
Moe Trin
Thanks for the explanation. I had thought that temp/tmp was a temporary holding place but that Drive Image 7 wasn't following that logic. My mistake, not Symantecs.
Smiley Burns
Well, how long is "temporary"? For an ice-cube in a cold drink, that could be minutes. On the other hand, the US Navy occupied "temporary" buildings built during World War One in Washington DC for more than fourty years. ;-)
The /tmp directory must be made available for programs that require temporary files.
Programs must not assume that any files or directories in /tmp are preserved between invocations of the program.
Rationale: IEEE standard P1003.2 (POSIX, part 2) makes requirements that are similar to the above section.
Although data stored in /tmp may be deleted in a site-specific manner, it is recommended that files and directories located in /tmp be deleted whenever the system is booted.
There's also a scheduled job that runs nightly on this computer that deletes anything in /tmp/ that hasn't been used in ten days. This is fairly common in *nix
Old guy
Moe Trin
