In article , goose wrote: :I have a pc with norton antivirus 2005; that pc is in a lan, and should not :have access to the web.
What, more precisely, is "the web" ?
:I've dropped the port 80 outgoing from that pc, but now i'm not able to run :liveupdate.
Where are you expecting the PC to get it's NAV updates if not from "the web" ?
:what can I do? there's a way to change the port used from liveupdate?
If you are trying to fetch the updates from Norton, you'd need the cooperation of their machines in order to have them serve the information on some other port.
