Hi, having difficulty in set up the link between my Netscreen, IDP and the internal network. The network is working, Switch (Untrusted Network) Netscreen switch (trusted network) I would like to add IDP between the Netscreen and the internal network to examine the decrypted packets. However, there is no signal at all. Switch (Untrusted Network) Netscreen IDP switch (trusted network) The ports of IDP are running in in-line mode and verified working fine,
Tried to place a switch between the netscreen and the IDP, then it worked. Switch (Untrusted Network) Netscreen Switch IDP switch (trusted network)
Is there something that I have missed? What cable should I use if I want to connect my Netscreen to the IDP directly. Huang
