I have two Netscreen 100s with ScreenOS 2.6 setup in a HA failover configuration. The problem I'm having is that when I sync the two units, the slave box gets an exact copy of the masters configuration and then shuts down all duplicate IP addresses, including the external untrusted port. This means that the slave cant ping anything, and thus will allways generate failures when I set it up to track an IP.
Do I need to give the salve box a unique public IP via a serial reconfiguration of the masters setup? If so, why isn't this talked about in any of the documentation?
