Two systems are connected wirelessly to a Netgear DG824M Router/Firewall/ADSL Modem. I'm trying to open ports for both systems to be able to use the P2P application, "eMule".
The following rule works for my machine:
Service: eMule(TCP:4662) Action: ALLOW Always Send to LAN Server: 192.168.0.2 WAN Users: Any
but when I try to create an identical rule, except with the other machines LAN address, it doesn't work, unless it's placed higher in the list than my rule, but then mine doesn't work!
So how should I go about opening a port for 2 systems?
Dave.
