NAT problems with PIX 501
Hi I've been setting up a pix at home, and it works pretty good. The only problem, is that NAT only works from one inside ip. When trying from other ip's i get the following in syslog: Oct 05 09:53:50 10.0.0.1 %PIX-3-305006: portmap translation creation failed for udp src inside:10.0.0.10/1025 dst outside:*.*.4.24/53 I've compared my config with other config's that's supposed to work, but I'm not able to spot the problem. Anyone care to take a quick look?
Config: PIX Version 6.3(5) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password * encrypted passwd * encrypted hostname pix domain-name *.cc clock timezone CEST 1 clock summer-time CEDT recurring last Sun Mar 2:00 last Sun Oct 3:00 fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names name 10.0.0.3 Eureka access-list outside_access_in permit tcp any interface outside eq 3389 log access-list outside_access_in permit tcp any interface outside eq 8082 log access-list outside_access_in permit tcp any interface outside eq 25000
access-list outside_access_in permit tcp any interface outside eq 3784 access-list outside_access_in deny tcp any any log access-list outside_access_in deny udp any any log access-list inside_access_in permit ip any any pager lines 24 logging on logging trap warnings logging host inside * icmp permit any echo-reply outside icmp permit any echo outside icmp permit any unreachable outside icmp permit any echo-reply inside icmp permit any echo inside icmp permit any unreachable inside mtu outside 1500 mtu inside 1500 ip address outside *.*.*.106 255.255.255.252 ip address inside 10.0.0.1 255.255.255.0 ip verify reverse-path interface outside ip verify reverse-path interface inside ip audit info action alarm ip audit attack action alarm pdm location Eureka 255.255.255.255 inside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 static (inside,outside) interface Eureka netmask 255.255.255.255 0 0 access-group outside_access_in in interface outside access-group inside_access_in in interface inside route outside 0.0.0.0 0.0.0.0 *.*.*.105 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout sip-disconnect 0:02:00 sip-invite 0:03:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local ntp server * source outside prefer http server enable http 10.0.0.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec crypto ipsec transform-set ESP-3DES-MD5 esp-3des esp-md5-hmac isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet timeout 5 ssh 10.0.0.0 255.255.255.0 inside ssh timeout 30 console timeout 0 dhcpd address 10.0.0.2-10.0.0.15 inside dhcpd dns * * dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside username admin password * encrypted privilege 2 terminal width 80
Sk0yern
It's because you only have 1 IP and you are using a 1 to 1 static. You need to use PAT for that static.
Paste in the below:
clear xlate no static (inside,outside) interface Eureka netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 3389 Eureka 3389 netmask
255.255.255.255 0 0 static (inside,outside) tcp interface 8082 Eureka 8082 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 25000 Eureka 25000 netmask 255.255.255.255 0 0 static (inside,outside) tcp interface 3784 Eureka 3784 netmask 255.255.255.255 0 0 clear xlate wr mem
Brian V
He has PAT configured.
chris
Apparently you missed: static (inside,outside) interface Eureka netmask 255.255.255.255 0 0 Make the global pat statement useless.
Brian V
Errr no! You can still have statics and have PAT for everything else! For example I have statics for my mail server and FTP server but everyone else is PATed out using the above commands. Having a static NAT statement for one host doesn't mean that PAT won't work for anything else. That would just be silly wouldn't it?
chris
On my Pix ..
static (inside,outside) globalmail mailhost netmask 255.255.255.255 0 0 static (inside,outside) globalsrv srv netmask 255.255.255.255 0 50
nat (inside) 1 0.0.0.0 0.0.0.0 0 0 global (outside) 1 interface
So I static NAT for two hosts on the network and then the rest of the network gets PATed to the outside address. This is a quite a normal set up and certainly having statics does not "make the global pat statement useless"!
Chris.
chris
Chris, You are missing the HUGE fact that he only has 1 IP address. It is assigned on the outside of his firewall. When you have a single IP you cannot do 1 to
1 NAT's. You must do PAT's on everything including your static statements. In your pix/asa you have a minimum of 3 IP's, one on your outside interface, one thats mapped to globalmail and one thats mapped to globalsvr.
-Brian
Brian V
Brian V skrev:
That was the trick, thanks alot.
Sk0yern
Brian,
Yes, I missed that. I thought that he had two addresses and had a static for one.
Sorry. You are quite correct.
Chris.
chris
