MSN Messenger and Outpost
Hi all!
How can I create a rule in Agnitum Outpost 3.5 for direct connections in MSN Messenger 7.5? Especially it is important for me to allow a necessary remote ports for direct connections. If it is possible, please, quote me a specific example.
Vasiliy Efimenko
hey vasilliy This is happening to me at the moment.it started when i just installed the new version of msn messanger and now it won't let me sign in. It keeps saying things about firewalls and proxy but i havent a clue wat they are. i carn't find out what they are but i did find out that your have to change your firewalls settings and then it might work. I hope that helps you bibi kate
katie321
Hello, Kate On 18.02.2006 18:30 you wrote,
Thanx, Kate, for your comments.
I resolve my problem by creating follow new rule for my MSN Messenger: Protocol: TCP Direction: Inbound Local ports: 1000-1200
The range of local ports I taking approximately by little experiments results. I not sure how it rule correcting in the view of security but direct connecting while I receiving/sending files works.
Vasiliy Efimenko
