Lsas.Blaster.Keylogger is a trojan. it has infected thousends of pcs arround the world. if your pc has got Lsas.Blaster.Keylooger, see how to remove steps at
- posted
14 years ago
More importantly, once a keylogger was installed on your system your work isn't done with removing the infection. You need to change every single password and PIN you used on/through that system ASAP.
cu
59cobalt"More importantly, once a keylogger was installed on your system your work isn't done with removing the infection. You need to change every single password and PIN you used on/through that system ASAP."
Thanks for this great info, @ ANSGR
