Hi all,
I'm looking for a low-cost system to install Linux and firewall software on. Someone recommended that I use a cheap $200 system, but most cheap computers are going to be fairly power hungry. I've been told that the cost for power and cooling for server room equipment is about US one dollar per year. At that rate, the cost of power for the firewall could outweigh the cost of the hardware within a few years.
With this in mind, I've been looking for a reliable, fairly cheap ($400 to $500), very low-power (around 20 watt) system with 2 or 3 gigabit Ethernet ports, 256 MB to 1 GB of DDR II RAM, 40 to 80 GB hard disk, USB ports, and a PCI slot for expansion. I've found many 1.5 GHz VIA C7-based systems that fit the bill, for example:
I've also found some ultra-low-power Celeron-based systems that meet my criteria, but they never have any prices listed. Does anyone have any price information for Celeron-based systems similar to the above VIA C7-based systems?
More generally, for those of you who have set up a firewall on similar hardware, what have been your experiences? Have any of you accidentally bumped the power button some of these units have unexposed right on the front panel? What version of Linux would you recommend, a special embedded Linux, or a full-featured Linux like CentOS? Are there other processors besides VIA C7 and Celeron I should be considering? Most importantly, does the 1.5 GHz VIA C7 have enough horsepower to serve as a firewall between two gigabit Ethernet LANs?
Thanks, Steve
