Hello all I just upgraded from zonealarm pro to kerio version 4.2.3, used
tia in advance
Dee.
tia in advance
Dee.
Kerio should be blocking this unless you have allowed some service/app access in both directions on this port.
At any rate, I found this info which you might try also:
The HKEY_LOCAL_MACHINE\\Software\\Microsoft\\OLE registry key has "EnableDCOM" as a named value. By default this value is set to "Y." To disable DCOM, change this value to "N." You can do this in the OLE/COM Object Viewer with the File.System Configuration dialog box. Changing this value requires you to restart your computer.
I don't know if it will work or not, but it might be worth a try.
Have you tried the official support forum?
Yes so far I cannot find anything.
Ah, sorry - but if no one in
It does the job.
Thanks
Dee.
