Has anyone used/installed ipcop firewall? Is it easy to setup/install? Do all the nic's need to be a different make/model? Can you have 4 nic's?
Thanks
Thanks
Yes, yes/yes. No and no
Jason
Ooops I cant count. Yes it can have 4 nics. 1 red/internet, 1 green/trusted, 1 orange/dmz, 1 blue/to a wireless ap.
Jason
Thanks for all the information. :-)
But I th>* gene martinez :
It can have 4 nic's, 1 green for the trusted, one blue for the wlan, one orange for not that trusted eg. if you have an webb server or/and for e-mail and than you have the red one for the connection to the world or if you want another network.
regards Anders
The pc I want to install it on does not boot from cd, So what are my options to do the install?
Thanks
Thanks
NICs don't have to be of different makes/models. Have a 2 NIC ipcop system. The NICs are 3Com and are the same model number (even down to the revision number).
Can it boot from floppy?
Jason
Think so...
There are three possible ways to install IPCop.
