Hello, i need your help
I work with the nokia IP 130. And i don't know how can i do for testing the connection between IP30 and the Active Directory.
Sorry for my english.
Are you wanting to use Active Directory for authentication to the Nokia?
Wayne McGlin Brisbane, Oz
yes i want to use AD.
You can use an account to test the connection between IP130 and AD. Use that account to login and you can get a log at your Windows server.
For establishing LDAP connection, follow the steps below
6.Click "Fetch Branches" to get the information from your AD server.
Good Luck
thanks a lot, i'm going to try it.
I keep you up to date on the situation.
It's worth mentioning that SmartDirectory requires a license, and isn't included unless you have a Pro bundle (not Enterprise):
