I need help choosing a firewall/vpn solution.
Threaded View
I need help choosing a firewall/vpn solution.  I would MOST appreciate
anyones help in making this choice.  I have been reading these
newgroups, speaking with sales engineers and trying to make the most
intelligent decision on my own.  I have to admit the more I learn the
more I can define what I need...but cannot determine a final product
selection.
We are a small business with limited funds.  When I spoke with Cisco
they told me that they had a small-business solution designed to be
both affordable and easy to use.  It was only $15,000 !!!  I guess
Cisco is too big to know what a small-business budget is. :)  I would
like to keep my budget between $2000 and $4000.
Here is what I really need to purchase.
I want to purchase a new firewall/UTM device to replace my aging
SonicWall Pro 200.  I need this device to be able to route traffic with
different rules for each route AND act as a DHCP server.  I will try
and explain what I mean by this with an example.  I have a network of
around 25 computers and 4 servers..  We have a block of 64 public ip
address that are using for external access.  The 4 servers are as
follows:
1. Microsoft Small Business Server 2003 with Exchange Server running.
2. Microsoft Windows Server 2003 with Citrix Presentation Server
running.
3. A Windows XP security camera server with proprietary video remote
services.
4. A VOIP PBX telephone server (not connected currently...but want it
to be).
The 25 computers consist of primarily Windows XP boxes with a couple of
Mac OSX and Windows 2000 boxes.  We also have around 10
network-connected devices (i.e. network printers, scanners, time
clocks, etc.).  We have 5 mobile users who need to be able to connect
to our network through some type of VPN solution.  We also have a
branch office that has a SonicWall TZ170 Wireless.
My requirements for this project are as follows:
1. The device(s) must be a DHCP server for our internal network
(192.168.168.x).
2. The device(s) must be able to reserve internal addresses for certain
devices so that they will always keep the same ip (so that our ip
printers & devices will always be at a certain 192.168.168.x address).
3. The device(s) must be capable of taking requests for various
external public IP addresses and transferring that traffic to static
internal-network devices.  In example, taking our external IP address
64.207.227.12 and route that traffic to our internal network Exchange
server residing at 192.168.168.15.  This feature must be able to apply
different security policies (open port settings) to different
extIP/intIP translations.  We need to lock down our Exchange server as
tight as possible and allow our camera server to be almost wide open.
THIS IS VERY IMPORTANT AND IS THE MAIN REASON THAT WE ARE REPLACING THE
SONICWALL PRO 200, AS IT IS NOT CAPABLE OF THIS FEATURE.
4. The device(s) must be able to connect to our Branch Office's
SonicWall TZ170 Wireless device creating a VPN tunnel so that the users
at that office are able to share our network without having to run
local VPN software.  (I might be willing to replace the TZ170W if the
solution required it)
5. We currently use the VPN solution provided in Microsoft's Small
Business Server 2003.  We like this because it doesn't require any
extra software on the remote users computers.  We are however
interested in replacing this with an SSL VPN device for ease of use and
cross-platform support.  We have several users that would like to
connect via their smartphones and know that this is an option with some
manufacturers SSL-VPN products.  It would be nice if this SSL VPN
device could verify that the connecting user has virus software
installed PRIOR to letting them connect.
7. Must be easy to setup and maintain.  If we add another server it
must be easy to create a new public-to-private iIP route with unique
policies/rules WITHOUT disturbing the other previously configured
settings.  This is one problem with our current SonicWall Pro 200...we
tried to install a new VOIP server and we couldn't open the ports for
just that device...we had to open them for all the traffic.
I sincerely appreciate your help and if I can do anything to help
clarify my needs please let me know.  I cannot tell you how grateful I
am for the help.
michael
Re: I need help choosing a firewall/vpn solution.
michaelb wrote:
<snipped>
WatchGuard and SnapGear have FW appliance solutions in your price range.
http://www.cdw.com/shop/search/results.aspx?key=watchguard&sr=1&platform=all&x=30&y=9
http://www.watchguard.com /
SnapGear
http://www.securecomputing.com/index.cfm?skey=1485
If you want to know more about the products, then I suggest you get on
the phone with them and go to their Web site and look at product spec.
sheets.
<snipped>
Why ? , you have W2K3- Servers, which can do the job better, than every
firewall i know.
On DHCP-Server: static entries, on Firewall dito. no problem.
OK, but you don't need only a new firewall (hardware), you need a
concept. Never allow traffic from the untrusted to the trusted network.
Therefore exists a DMZ. if you are running Exchange and IIS public
visible in the internal lan, you don't need a firewall, you can use a
simple router, the security is the same.
If it is a standard IP-sec VPN, it should be no problem with most solutions.
a VPN endpoint in the internal lan: brrrr.
VOIP is a problem, because it oftens has the need of dynamic ports. This
is also a must to place him in the DMZ
OK, some ideas for firewalls:
1. Astaro (www.astaro.com) as UTMS-Firewall, but you have to look for a
consltant in your region.
2. Cisco ASA 5505 or 5510, depending on your real needs.
3. take a look to M0n0wall (http://m0n0.ch/wall /) and spend money for
servers and proxies (as ALG) in the DMZ.
A budget from 0€ (m0n0wall) up to 3000€ Astaro, Cisco ASA 5510, without
implementation is imho realistic.
bye
Christoph
Michael,
I am a Sonicwall partner. They have a number of different possibilities that are
well within your price range. I would be happy to discuss what Sonicwall can
offer you. Feel free to give me a call at my office or drop me an email at jamie
at danmarkcom dot com.
Posted via http://www.firewallalarms.com
Sorry. I left off my office number in the last post, and I can't seem to get the
edit to stick. My office number is 256-766-1580.
Posted via
mbolick@gmail.com says...
Bad move - SBS should be the DHCP server and the only DHCP server on any
network where you use SBS, if not, you stand a real problem with
resolution. It should also be the DNS server for all of your computers,
including itself.
Firewalls don't do that, that's a function of your internal DNS and your
ability to create a DHCP reservation in your SBS Server.
Most every firewall can do this - WatchGuard is my choice, and you can
have multiple HTTP rules or SMTP rules, that you can define as from IP
Z.x.c.v or V.d.r.f or anything, and you can map them to any internal IP
and even a different port if needed.
Simple, Watchguard, as well as most others, act as IPSec VPN
endpoints/servers.
WatchGuard has a SSL VPN appliance, and their firewalls, X550 and above
act as PPTP VPN Servers, so your users can connect to the firewall and
then have rules applied based on their user/group (on the firewall) to
limit their access to the SBS network. You don't need a Dual NIC
solution then, making life a LOT easier for branch office solutions.
WatchGuard does this, has done it for years, and it's simple.
VOIP is simple, but you have to understand how VOIP works and the
requirements, it also helps to know the ports that are bring use.
www.watchguard.com - call them or email me.
You really need to fix your network, SBS should be the DHCP server as
well as your ONLY DNS server for you to properly use SBS.
spam999free@rrohio.com
remove 999 in order to email me
Thank you for your suggestions so far.  I am learning tons.  I probably
need to hire a consultant but in my budget it isn't easily done.  I am
glad that I have this forum to help me make the decision.
Thanks again for the recommendations.
Keep them coming...even if only to flame my original post.  I take
constructive criticism pretty well.  ;)
I would recommend you take a look at a lower-end Sidewinder G2 appliance
while your researching firewalls
http://www.securecomputing.com/index.cfm?skey=20&lang=en
I've used them for years and they are rock-solid.
I also suggest that you only use the firewall to allocate DHCP to your VPN
clients and use an internal DHCP server for the internal clients.
Site Timeline
