OK - minor point; you are not scanning "all" ports on the firewall though this may or may not be relevant. See the -p option. Also, if your firewall is "reacting" to your probes by adding a temporary or permanent rule to "protect itself" from "attacks", you may want to read about nmap's -D option and think what would happen if one of those addresses used were that of an upstream router, or your DNS servers.
A lot depends on the rules set up on the firewall. COMMON SENSE suggests that the firewall does not accept _any_ connections from the world. Some people configure the firewall to 'REJECT' (reply with ICMP Type 3, Code 3, 10 or 12) any connections, while others configure the firewall to 'DROP' ("blackhole", "ignore", or "stealth") any connections. This is a "religious" decision, and is not part of this reply.
If you must permit connections from the "outside", a firewall rule should restrict the number of "permitted" outside addresses. Some advocate moving SSH (using any other service to connect to the firewall is totally insane) from the default port (22) to some other unconventional port (a form of "security by obscurity" - but a good defense against st00pid skript kiddiez and 'bots), while others suggest using 'port-knocking' (requiring a connect attempt to an otherwise empty port, followed within time limits by a connection to the "desired" port from the same address). Another technique is to only accept connections from "inside", and if a connection is needed from "outside", then you SSH into the "inside" host, and SSH _from there_ into the firewall. However, don't get to "clever" with your firewall, as you may only block everyone _including_ authorized personnel.
Thus, a "properly" configured firewall is going to be difficult to probe. It will either reject all attempts (possibly allowing you to fingerprint the O/S based on the ICMP errors), or simply _ignore_ all connection attempts (though still locatable by the lack of an ICMP Type 3 Code 1 from the preceding router).
