Windows Update connects to anyone of hundreds of thousands of possible IP addresses that match the general DNS name pattern:
a99-99-99-99.deploy.akamaitechnologies.com
Is there any way with Firewall-1 Next Generation to create a security rule that passes all such hosts based on the domain name?
When I create the rule using either domain:
akamaitechnologies.com deploy.akamaitechnologies.com
the rule does NOT match to the connection attempt.
I don't want to specify a network or address range since Akamai is used by huge numbers of companies and I don't want a rule that is too permissive. I'm hoping that they might at least restrict the deploy.akamaitechnologies.com subdomain to a subset of all of their customer uses. Is there any way to get Firewall-1 to pass traffic going to this subdomain?
