I've googled and found several VPN primers but they seem to skip over the issue of the client's IP. If it is virtually part of a LAN, then the client must appear to the LAN as a local IP address, no? Is it statically set at the client or does DHCP work through the tunnel or what?
- posted
19 years ago
