I got a used Sonicwall SOHO2/10 firewall appliance off of eBay. It was reasonable ($200) and the owner transferred all of the registration to me so I can download firmware and such from
So now I disconnect PC from LAN port, plug PC back into port 1 in Linksys and plug the Linksys back into the firewall. Nada! WTF! I can ping my other PC in the other bed room and my JetDirect print server, but when I try to ping my firewall, whose address I changed to
192.168.1.60, the same addressing before I get the firewall, I get nothing! It's as if the firewall turns itself off when it detects that it's being plugged into the router (the firewall WAS pingable when I had it hooked up directly to my PC).Needless to say, this firewall will be pretty useless if the only way it works is with one PC and not a router. I would like to protect the other PC that has a wireless connection by putting it behind the firewall.
Thanks for any advice.
Adam
