Hi, i have critical problem here. there is a antivirus soft just came from nowhere and it is running on the taskbar on the right side. So, i thought it was spyware and i run the malwarebytes-antimalware to remove it. So, it can and gave me three threats and i deleted them. After i restarted my computer, there is a "dob" sound keep appeared every 1 minute, and whatever i try to run it is not running. for example, i try to press alt + ctl + delete to end that antivirus soft, it prompted me tsk.exe cannot be executed. then i try to run click on the control panel and it gave me that appdll.exe cannot be executed. Een i try to run the malwarebytes , it is failed.
Now, i couldnt open my microsoft words file and all the other files. Help! thank you!
