Hello,
I use various programs to such as Ultraedit to upload files via FTP. On one site, all of a sudden I began having a mysterious problem. I can log onto the site, but I cannot do anything alse. I am able to get the name of the directory I am in but I can't get any other directory information, change directories or access any files.
I am only having this problem on one site. All my programs, smartFTP, WSFTP, HtmlKit , NVU were effected at the same time, except WinSCP which still works fine. The Server tech had changed some firewall settings but has been unable to figure out what the problem is. I'm still suspect it has something to do with the firewall settings on the server. It only seems to effect my account, It doesn't make a difference if I use passive or not passive, or if I take down all firewalls on my end. I double checked that it is not something on my computer by using another computer, albeit from the same location. It had the same problem.
Here is one attempt by htmlKit, in non passive mode:
HtmlKit: FTP > PWD FTP < 257 "/home/trt/www/html/website.com" is your current location FTP > PORT 192,168,1,101,4,110 FTP < 500 Unknown command FTP > 500 Unknown command FTP - Could not get directory list. (933) FTP > CWD /home/trt/www/html/website.com FTP < 250 OK. Current directory is /home/bvb/www/html/website.com
Any Idea what it could be ?
I had the idea that if I could possibly see the requests that WinSCP and UltraEdit send to the server, I could compare them and and possibly see what is working and what is not. If it were http traffic, I would use Charles
Thanks.
Red
