I recently had to reset to factory defaults on my watchguard SOHO 6 firewall and lost all my routes I had setup for two P2P locations. I thought I remembered how this was setup before but cant' seem to figure it out.
Here is our current setup.
Main Location --> LAN IP Address - 192.168.111.3/24 Serial 0/0 IP - 172.16.2.1/30 (P2P Location #1) Serial 0/1 IP - 172.16.3.1/30 (P2P Location #2) IP Address Range - 192.168.111.1-254 Subnet - 255.255.255.0 Gateway Address - 192.168.111.1 (Firewall)
P2P Location #1 --> LAN IP Address - 192.168.1.2/24 Serial 0 IP - 172.16.2.2/30 IP Gateway Address - 192.168.1.2 IP Address Range - 192.168.1.1-254 Subnet - 255.255.255.0
P2P Location #2 --> LAN IP Address - 192.168.3.1/24 Serial 1 IP - 172.16.3.2/30 IP Gateway Address - 192.168.2.1 IP Address Range - 192.168.2.1-254 Subnet - 255.255.255.0
All P2P routers are configured correctly and up and running. I believe it is just the firewall blocking the connection to the main location. Thank you in advance for your help.
