Firewall port 1105 (FTRANHC) & port 1239 (NMSD) ?
Threaded View
Can someone shed light on this message from Sygate Personal Firewall?
Firefox (firefox.exe) is being contacted from a remote machine
www.google.com [66.102.7.104] using local port 1105 (FTRANHC - FTRANHC).
Do you want to allow this program to access the network?
1. I brought up firefox and went to google groups.
2. Sygate asked me if I wanted to go there at port 80 & I said OK.
3. Then, Google came back asking to come in on port 1105.
Why does Google want to remote initiate at port 1105?
Then I search for port lists and find this URL:
http://www.doshelp.com/trojanports.htm
When I go to that link, besides the request to go out on port 80 I get
another incoming Sygate permission request asking:
NDIS User mode I/O Driver (ndisuio.sys) is being contacted from a remote
machine www.doshelp.com [68.178.160.90] using local port 1239 (NMSD -
NMSD). Do you want to allow this program to access the network?
I say no, and the web page won't come up.
So I go to http://www.iana.org/assignments/port-numbers to find not much on
these two ports.
My confusion lies in why these web sites feel the need to contact me on any
port other than the port 80 that I go out to them on.
Can you shed light on what is the normal process here?
Thank you for your guidance,
Ellen
Re: Firewall port 1105 (FTRANHC) & port 1239 (NMSD) ?
On Fri, 6 Jan 2006 01:55:53 -0500, YoKenny wrote:
Hello YoKenny,
I had found the port list web site by searching for port lists (I wasn't
sure which is the "correct" port list web site). I guess that particular
URL is a bad port list web site.
But I may have accidently misled you. My real question really revolved
around why any web site (the reputable google included), would feel the
need to contact me on a DIFFERENT port than the port 80 which I initiated
communication on? And, if I rejected that request (which I am wont to do by
default), then why would my web request on port 80 therefore fail because I
rejected an incoming request from that web site on ports 1105 or 1239.
Ellen T.
Site Timeline
