Antispyware Soft reality: is a rogue anti-spyware program from the same family as Antivirus Soft and Antivirus Suite. Just like its predecessors, AntispywareSoft reports false system security threats to make you think that your computer is infected with malicious software. Usually, this fake program is promoted through the use of Trojans or other malware, but it can be also installed on your computer without your consent and knowledge through software vulnerabilities. For more technical information about Antispyware Soft and to learn how to remove it from an infected computer, checkout this tutorial
- posted
13 years ago
