I have a debian install on a machine with 2 eth cards,eth0 and eth1. eth0 has been configured using pppoeconf for a pppoe connection which is working fine. eth1 was meant to be there in order to provide for a nat so that an internet connection can be provided to another computer also using debian. The moment I plug in the cable to eth1 , eth0 stops working. (Is this caused maybe by hotplug ?) The goal was to actually get eth1 working also without breaking eth0's connection and afterwards make a nat using iptables. The same thing was done using Slackware and netconfig+pppoeconf and there were no problems. The pppoe is up using the pppd service and it was configured using pppoeconf.
I tried to find out the problem by trying to find out which file is beeing modified when I plug the cable in eth1 so I did strace ifconfig eth1 2>&1 | grep open I got a list of files and I suspect /proc/net/if_inet6 is the file that ifconfig modifies and reads thata from. So I decided to do sudo lsof | grep if_inet6 in order to find out what process uses the hotplug feature to autodetect when I put the cable inside eth1. Unfortunately I find no process that did this.
What should I do so that the internet connection doesn't drop when I plug in the cable for eth1 ?
