devide will reboot shortly
Threaded View
Why does our hardware firewall sometimes reboot?
this is the log just before the rebooting (this IP 85.18.xxx.xxx is my
IP):
2007-12-11 14:09:42    Local0.Warning    192.168.14.1    706703571CBAB IP:
discard from 207.46.106.77 port 1863 to 85.18.xxx.xxx port 35051 TCP
ACK (default) @2007-12-11-14:12:48
discard from 207.46.106.55 port 1863 to 85.18.xxx.xxx port 35076 TCP
ACK FIN PSH (default) @2007-12-11-14:12:48
2007-12-11 14:09:43    Local0.Warning    192.168.14.1    706703571CBAB IP:
discard from 207.46.106.28 port 1863 to 85.18.xxx.xxx port 35267 TCP
discard from 207.46.106.60 port 1863 to 85.18.xxx.xxx port 35239 TCP
discard from 192.168.14.117 port 3165 to 1.93.7.218 port 3193 TCP ACK
FIN (Attempt to send TCP packet on an unopen port)
discard from 212.247.9.195 port 443 to 85.18.xxx.xxx port 35162 TCP
ACK PSH (default) @2007-12-11-14:12:48
discard from 212.247.9.195 port 443 to 85.18.xxx.xxx port 35286 TCP
discard from 212.247.9.195 port 443 to 85.18.xxx.xxx port 33314 TCP
discard from 151.68.198.237 port 31209 to 85.18.xxx.xxx port 38129 UDP
discard from 82.49.188.196 port 12846 to 85.18.xxx.xxx port 38129 UDP
(default) @2007-12-11-14:12:49
discard from 216.155.193.169 port 5050 to 85.18.xxx.xxx port 31809 TCP
ACK FIN PSH (default) @2007-12-11-14:12:49
discard from 86.20.201.125 port 48057 to 85.18.xxx.xxx port 38129 UDP
discard from 81.75.222.210 port 50295 to 85.18.xxx.xxx port 38129 UDP
discard from 151.56.141.188 port 46262 to 85.18.xxx.xxx port 38129 UDP
discard from 87.13.26.177 port 6143 to 85.18.xxx.xxx port 38129 UDP
2007-12-11 14:09:43    Local0.Info    192.168.14.1    706703571CBAB IP: ICMP
type (3) code (3) received from 158.195.151.146 @2007-12-11-14:12:49
discard from 85.27.65.45 port 55450 to 85.18.xxx.xxx port 38129 UDP
discard from 86.12.254.248 port 39196 to 85.18.xxx.xxx port 38129 UDP
discard from 213.39.226.184 to 85.18.xxx.xxx ICMP type (3) code (3)
(SIP discarded) @2007-12-11-14:12:49
discard from 151.68.44.10 port 36639 to 85.18.xxx.xxx port 38129 UDP
discard from 82.58.157.86 port 5443 to 85.18.xxx.xxx port 38129 UDP
discard from 81.83.181.103 port 32845 to 85.18.xxx.xxx port 38129 UDP
discard from 82.84.111.204 to 85.18.xxx.xxx ICMP type (3) code (3)(SIP
discard from 85.201.5.70 to 85.18.xxx.xxx ICMP type (3) code (3)(SIP
discard from 91.171.152.138 port 11847 to 85.18.xxx.xxx port 38129 UDP
discard from 88.178.249.86 port 41026 to 85.18.xxx.xxx port 38129 UDP
discard from 85.231.106.180 port 20192 to 85.18.xxx.xxx port 38129 UDP
discard from 88.107.56.98 port 64693 to 85.18.xxx.xxx port 38129 UDP
2007-12-11 14:09:48    Local0.Error    192.168.14.1    706703571CBAB MONITOR:
critical task tNetTask suspended - device will reboot shortly
@2007-12-11-14:12:53
any idea?
Re: devide will reboot shortly
Do we get a hint as to what model and software version your
firewall is?
It's a WatchGuard Firebox X Edge X55
http://www.watchguard.com/products/x55e.asp
Thanks
Site Timeline
