I'm removing Comodo. I'm at the registry level, I have full rights, but it won't let me delete a key with comodo in the line. How do I get it out of there?
- posted
15 years ago
Don't the Comodo people have an uninstaller for their stuff?
Yours, VB.
Is it a Legacy key ? If so I don't think you can without risking your system integrity. Legacy keys are not 'used' AFAIK so don't worry.
If it's not a Legacy key then you just need to check privileges, its prob marked System only. Change the security and you should be fine.
It may be neccessary to re-install first before proceding with removing...
