Is it possible to upgrade the Cisoc OS on a PIX 515 from say version 6.3 to
7 and hence use ASDM?Thanks
In article , Gary wrote: :Is it possible to upgrade the Cisoc OS on a PIX 515 from say version 6.3 to :7 and hence use ASDM?
Yes, but if it is a PIX 515 instead of a 515E then likely the device does not have the minimum memory and would need a memory upgrade.
BTW, PIX questions are generally best put to comp.dcom.sys.cisco .
