hi,
what kind of info is available from the vpn? userid, last use, .....?
can you point me to a url that discusses this?
thanks
hi,
thanks
Userid: yes lasts use: yes
Check Point will log almost all information about your RA/L2L vpn connections.
You could check the SmartCenter/Smartview monitor documentation on the CP site, but those documents won't discuss all the options in detail.
I would advice you to install the Smart Console and run it in demo mode.
Br. Robby
thanks.
