Hi, been trying to get a vpn up and running for ages now. On my side I have a Debian box and on their side they have a checkpoint fw.
I now have a vpn up and running, the problem is that we are not getting any traffic back from them after trying to connect to their internal network through the vpn. I can ping their fw and get esp packages back without a problem. I figured it had to be a routing problem but they came back and told me that they have a setup consisting of two firewalls on their side and that both of these firewalls are working in "active-active" mode which is causing said problem.
Is there any way to fix this using racoon/ipsec-tools or do I have to invest in my own checkpoint fw to get around the issue at hand?
