Our Sonicwall content filtering service (CFS) is blocking this link:
TIA.
** Captain InfinityOur Sonicwall content filtering service (CFS) is blocking this link:
TIA.
** Captain Infinity
I don't remember where on sonicwall.com the list is, so if you can not find it, please reply in here and I'll try to help you and give you the list from the page belkin router links to.
Thanks for reporting back in here, I appreciate it, :)
When I said there's only 56 categories I just meant that Cerberian does that many. I totally forgot the sonicwall allows the custom one, ooppss.
Thanks, I found Sonicwall's list. The "help" section informed me that Category 99 is for "Custom Additions". One of the domains that has been manually entered in the "forbidden domains" section of the firewall setup is advertising.com, so I guess that's what's triggering it. (Although yesadvertising.com and advertising.com are not the same thing. It shouldn't be happening, but it is.)
By the way, Category 100 is logged if the firewall has a connection problem accessing a link.
** Captain Infinity
oh yeah, in the sonicwall if you click on help, it shows category 99 as custom. so that's the keywords entered.
