Best small business firewall/router with vpn
Hello I know this gets ask alot but I wanted an updated response. Which router/firewall is the best/most popular for small business setups. My setup has ~ 12 users inside. Need option for gateway-gateway vpn and possible future need for 1 or 2 client to gateway vpn connections. Thanks in advance!
PS I was hoping for < $200 but could go higher if there was a big benefit.
cdoc
I have been using the LinkSys (Cisco) BEFVP41 in an office environment for several years with little trouble. I have several VPN's set up with them at both ends. They do eventually fail after a few years but they are cheap enough (about $100) so its not a big expense to replace them. I'm sure there are better routers around but these are cheap and they work if you know how to set them up.
Concerned
