the new AVG is a HIPPOPOTAMUS!
Bleah!
Bleah!
Huh? what? ... and nothing. U wouldn't happen to know of some free antivirus thats a bit less blimpy, anyone?
(if not, i'll just start trying them out at random
Avast, Avira, or ClamWin
That's the best you can do. Don't forget to try BitDefender and Panda Cloud Antivirus as well.
In my humble opinion, freeware antivirus utilities are not the best solution. Especially on a corporate environment.
What do you think of Avg Rescue CD?
Thanks
Regards
didn't know there was one
Thanx folx, I'll check'em out as time permits.
(yeah, if it was for a corporate environment i probably would buy something, but its just for my own used and rather junky pc)
but not for the quality of the anti-virus recognition avast home free is absolutely wonderful imho.
but professional versions have features like error reporting, statistics the ability to push out updates from a controlled server, no licensing issues, ...
which makes them a lot more useable in a corporate env.
avast home free, avira (not sure of the most recent version -- it's been a while), nod32 is also pretty lightweight but on some independant testing it scores very low.
Since someone has started a thread on AVG, I would like to ask:
Has anybody experienced any conflict between AVG Free Antivirus and the Windows XP firewall? I have AVG Free 8.5 and every time my computer starts up and AVG is loaded I get a warning "balloon" that my firewall is turned off. The balloon then disappears and when I check my security settings the firewall *is* turned on and everything seems OK.
Is this a problem that is confined to AVG 8.5 or something to cause serious concern?
