Astaro or Checkpoint?
Hello everyone, I need a suggestion, I have to replace a Zywall 5 with a better product. My experience with Zyxel is not good, low performance and too many false positive with IDP filter. I have read some datasheet of Astaro (120/220) and Checkpoint (UTM-1 Edge Appliance) products, in your opinion which is better? These are the feature I want:
- Router/Firewall
- At least 4 port for LAN / DMZ (6 if possible)
- IDP/IDS functions (if possible also antivirus function)
- Web Content Filter function
- At least 5 VPN connection
regards exch
Exch
WatchGuard X550e devices with UTM are going to offer a better path.
If you really need 6 different DMZ Networks you will need a x1250E device, if you just need 6 DMZ IP addresses, well, they really are not a DMZ if they are in the same network as your LAN.
A WG firebox unit will provide LAN, WAN, DMZ network jacks, you assign rules based on paths between those networks - they are real networks, meaning that the DMZ is its own network, not just an IP inside the LAN.
Leythos
Take a look at Juniper Networks SRX 210. It has all the features you need and even more. Price is reasonable. In my opinion much better than Astaro or CP UTM-1 Edge.
-- Regards Vit
vit
We use the Astaro products here (ok bigger site so we have the 625), We dont have any complaints. Have a look at the forums on
feel free to email me if you have any questions regarding astaro :)
Phil
Phil
