Howdy all,
Our company policy is to have two factor authentication to administer firewalls. This has been good for console and SSH administration of Cisco ASA and PIX firewalls. However we are now moving to Cisco Finesse image 7.2X and would like to use the ASDM. The ASDM appears to cache the credentials and retry authentication/ authorization for each consecutive command issued. i.e. Show run, show interfaces, sh route, etc etc. This obviously does not go down well with our 2 factor authentication solution (SafeWord), which expects a different token for each consecutive authentication request.
Could anyone advise of way to make the connection between the ASDM and the firewall permanent (so each command does not require authentication), or perhaps some wizardary on the AAA configuration???
Thanks in advance dirk
