Antivirus system pro is a rogue spyware fake program. This program is a scamware and is desgined to extort some extra monry from users by forcing users to purchase Ant Virus System pro. Please do not buy it. if your pc has got a popup alert of ANTI VIRUS SYSTEM PRO, this means you are infected by this rogue spyware. Then you should remove it from your pc. to remove antivirus system pro virus from your pc, follow the manual removal steps from this page
- posted
14 years ago
