Remove Fake AKM Antivirus 2010 pro rogue spyware it is a fake spyware remover which, just like initial Your PC Protector, is developed to trick the money out of unaware computer users. Distribution methods of AKM Antivirus 2010 Pro stay the same =96 malware gets into the target system through Trojans or fake online scanners. After this secret invasion, it trends to stop legitimate security software to protect itself from the elimination and then, upon each system launch, starts to mislead its victims. When removing, you will have to stop both AKM Antivirus 2010 Pro.exe and C:Program Filessvchost.exe processes because they will continue to launch this rogueware even the one of them is terminated To get rid of this virus known as AKM Antivirus, follow the removal instructions from this tutorial
- posted
13 years ago
This virus can also be removed by using an antispyware program like Malware Bytes or Super anti spyware Good Luck
