Advice on router security alert?
I'm based in the UK running Windows XP. My netgear router has sent me the following "security alert" email:
UDP Packet - Source:67.159.44.180,4237 Destination:83.245.16.37,1025 - [DOS]UDP Packet - Source:67.159.44.106,4237 Destination:
83.245.16.37,1025 - [DOS]UDP Packet - Source:67.159.44.180,4237 Destination:83.245.16.37,1025 - [DOS]UDP Packet - Source: 67.159.44.106,4237 Destination:83.245.16.37,1025 - [DOS]UDP Packet - Source:67.159.44.180,4237 Destination:83.245.16.37,1025 - [DOS]UDP Packet - Source:67.159.44.106,4237 Destination:83.245.16.37,1025 - [DOS]UDP Packet - Source:212.58.227.104,21922 Destination: 83.245.16.37,6970 - [DOS]
I've looked up the IP addresses and found the following:
=============================== Search ARIN WHOIS for: 67.159.44.106
OrgName: FDC Servers.net, LLC OrgID: FDCSE Address: 141 West Jackson Blvd, Suite 1135 City: Chicago StateProv: IL PostalCode: 60604 Country: US
====================================== Search ARIN WHOIS for: 212.58.227.104
OrgName: RIPE Network Coordination Centre OrgID: RIPE Address: P.O. Box 10096 City: Amsterdam StateProv: PostalCode: 1001EB Country: NL ====================================
So what does this mean??
martin_pentreath
It means that a host at BBC, a host presumably owned by a Mr. McElvana, and a third host sent a couple UDP packets to your netgear router (to ports that seem to be closed). And that your netgear router thinks that it might be a Denial-of-Service attack, for whatever reason.
With the given information that's all we can say.
cu
59cobalt
Ansgar -59cobalt- Wiechers
NOTE: Posting from groups.google.com (or some web-forums) dramatically reduces the chance of your post being seen. Find a real news server.
Missing timestamps, so it's hard to say. However the list was produced in this post, it makes it hard to read, but that's OK because there is virtually nothing interesting. There are six repeats of a UDP packet from some unidentified servers that may be in Chicago, destined for an ephemeral port often used by windoze for messaging. The fact that the first six alternate between two source addresses but use the same source port is interesting. UDP itself is stateless, so the source address could easily be spoofed (normal in messenger spam). The seventh packet is from a different host - perhaps rmclip4.rbsov.bbc.co.uk as the lookup implies. Pretty useless information, don't you think?
I've no idea what "tool" you attempted to use, but it's nearly worthless. It appears to be querying the ARIN whois server, which is a _step_ in the right direction, but there is no followup to the leads. "FCC Servers.net" has a referral server, but it returns nothing useful. Likewise, a hostname lookup shows rather clueless results.
67.159.44.179 alwayz.wazted.com.ar 67.159.44.180 is.lost.in.the.kingdom-of-anime.org 67.159.44.181 will.tradesex.net
Looking up other hosts (67.159.44.105 through 67.159.44.107, and
67.159.44.170) returns only the in-addr.arpa name which implies that fdcservers.net doesn't want you to know the actual name, or that they are to st00pid to be running a computer - your call.
Doing a search for the name 'fdcservers.net' in the Usenet newsgroups news.admin.net-abuse.* turns up lots of hits in 2003-2005, but not much of interest to me. You _are_ using a search engine to post - did you try using it for it's intended purpose of searching the web?
Totally useless tool. See
hints. There are five "Regional Internet Registry" - AFRINIC which handles Africa, APNIC which handles Asia and the Pacific, LACNIC which handles Central and South America, RIPE for Europe, and ARIN for North America and crumbs. Asking the wrong server will result in a hint (as here) to ask the right one. Here, the range 212.0.0.0 - 213.255.255.255 is delegated to RIPE (although there are some residual AFRINIC registrations from when RIPE was still doing registry for Africa).
Old guy
Moe Trin
