Hello,
The firewall in my 3Com 3CRWDR100A-72 router/ADSL modem is causing a strange problem:
When logging into my ISP site (Tiscali) I am unable to sign in, I get the usual, "Unable to display the page, check your settings etc." When this occurs I am unable even to go back and access the Tiscali home page, although all other non-Tiscali web sites are accessible. Waiting 20 minutes allows me to access the Tiscali home page, but I am still unable to sign in.
I assume that there is something in the Tiscali sign-in procedure that looks "suspicious" to the firewall. Disabling the firewall in the router allows me to access and sign in without any problem.
I cannot see any means of re-configuring or changing any firewall parameters in the router.
Is this something I have to live with, or can anybody suggest a workaround? I would rather have a single firewall in the router, than use a software solution in each PC.
FYI there are 2 PC's connect via cable to the router and 1 laptop and a PDA connect via wireless.
Many thanks for taking the time to read this request.
Chris
