I am trying to help a client. Basic problem is that with the SBC provided 2wire ADSL/router he has, I seem unable to use a static assigned IP address as a port forwarding destination, as it does not "appear" on the device list the "Home network" page, as opposed to devices that are DHCP (dynamically) assigned an address.
2Wire quickly responsed to my email, but frankly, their answer sounds a bit odd. I've requested followup, but haven't had any (yet.) This is an important client who is a distance from my home, and I can't afford to be "experimenting" as I don't wan't to errode his confidence in me. Unfortunately, I don't have the same equipment to test.Below is my conversation to date with 2Wire -- is there a kind soul who can help me verify their "solution"?
Thanks,
d.
{MY ORIGINAL MESSAGE}
I'm having trouble configuring my 1800HG to use a device using a static address as a port forwarding destination.
Internally, I can reach the static address device without a problem.
THe problem seems to get the device to appear in the list of devices on the "Home Network" page. Without this, the device doesn't appear in the list of devices "Choose the computer that will host applications" on the "Edit firwall setttings" page.
Is there a way to get a static address device to appear on this list, so I can complete the port forwading instructions?
THank you
d. ===================
{REPLY}
Dear D,
Thank you for contacting 2Wire Customer Support. The following is intended to answer your inquiry:
Try these steps.
Assign the device an IP address between 192.168.1.33 and 192.168.1.62. Turn the device off then back on to renew its address with your Home Gateway. You should be now able to see that device in the Home Network list to configure it.
If this response has not answered your question or resolved your issue you may visit our support Website at
Thank You, John C.
2Wire Customer Support=======================
{{My followup}}
Thank you for your prompt response.
Because this setup is not near my home (this is for a client), I'd appreciate if you would explain the special significance of the address range 192.168.1.33 thru 192.168.1.62, as I couldn't find any in the documentation. Is there a special (undoumented) error or limitation requireing the use of that range only?
Thank you.
d.
