I'm a student,inexpert user of the fiber,and i've this problem to solve >with low cost:
>i've an optical modulator (Mach Zehnder interferometer) without one of
>the two fiber connectors. so if i have to use this item i must put the
>connector to the other one fiber.
>The problem is that i don't have any splicer, microscope,crimp tool
>,what i have to do?There is somenthing easy to use for make the
>connection?Thanks matteo
You could use a bare fiber adapter, such as:
This is only a temporary solution, but is OK for lab use. Insertion loss is likely to be higher than compared to a normal connector.
Not that you will need to inspect the end of your fiber, and cleave it if necessary. If you do not have a cleaver, then using the bare fiber adapter will probably not be an option for you.
