pump power combiner
Threaded View
hi
is it possible to combine two pump powers at 980 nm, say 100 mW each to
get 200 mW output. A standard 3dB coupler would give only 100 mW at the
output...
Deepa
Re: pump power combiner
In order to combine the two 980nm light, you need a polarization beam
combiner (PBC). Basically one beam will be s-ploarized, while the other
one is p-polarized.
There are quite a few fiber optic components companies selling this
product....a simple google will do
Photonicist
deepa.venkitesh@gmail.com wrote:
Photonicist 86E993BC=9A
I can supply you the Polarization beam combiners. Maybe you also can
search AC photonics , They also can make the componts according to your
methods.
I am from China. If you have some specification, that would be great.
Kindly regards
Voeray
Site Timeline
