Fiber Optics problem with splicing 200micron fiber
Subject Author Date
problem with splicing 200micron fiber pandianchangedforever@gmail.co 10-17-07
Posted by pandianchangedforever@gmail.co on October 17, 2007, 3:28 am
Dear friends,
I have a 200 micron fiber ( 200 micron core/ 220 micron clad/ 250
sheath)
the splicing machine we have is capable of splicing the same. however
we are unable to cut the fiber ( after removing the sheath) flat.
The cleavers provided with the splice machine is meant only for 125
micron max.
can anybody suggest a way to cut fiber flat.....
also is it possible to use some laser to cut the fiber, for the same?
regards
Pandian,
research scholar,
Fiber optics,
IGCAR, India
Posted by DM on October 17, 2007, 5:45 am
pandianchangedforever@gmail.com wrote:
> Dear friends,
> sheath)
> micron max.
> regards
> Pandian,
> research scholar,
> Fiber optics,
> IGCAR, India
For such a huge fibre I'd just try with a good old simple axe cleaver. Don't
know if you still get them commonly anymore...wait a minute... one of my
suppliers has something similar in a catalogue as cleave pens.
http://www.fibreoptech.co.uk/Product.asp?ProductID=400p
and FIS has several options
https://www.fiscatalog.com/ see under tools- then scribe tools
This is basically a sharp sapphire blade in a handle.
with a bit of practice you can achieve reasonable perpendicular cuts.
One clean touch of the blade to the fibre about 10-15mm from the fibre end
then gently bend the fibre to encourage crack propagation.
Given that the fibres are highly multimode, as long as you have a reasonable
cleave (not perfect) and good splice parameters for this fibre then the
losses should still be OK
cheers
David
Similar ThreadsPosted
problem with splicing 200micron fiber October 17, 2007, 3:28 am
problem of a fiber cleaver July 24, 2007, 2:59 am
Splicing HI980 to HI1060 September 5, 2008, 6:14 am
Sell Fiber Optic Splice Closure,Splice Enclosure,Fiber Optic Closure,Optic Fiber Cable Connection Box December 1, 2005, 11:58 pm
Fiber to Fiber Coupling April 22, 2007, 2:26 am
Fiber in NYC October 1, 2005, 7:11 pm
where can i buy some bragg fiber September 21, 2005, 1:22 am
Identifying fiber September 28, 2005, 8:15 am
Fiber Cladding November 19, 2006, 6:58 am
Need Fiber For My Artwork August 16, 2007, 4:03 pm
Mid IR fiber supplier November 13, 2007, 3:56 am
switch for fiber December 23, 2007, 5:21 pm
Locking Fiber SMA August 25, 2008, 9:05 am
fiber optics link in ns-2 September 14, 2005, 9:05 am
where is bragg fiber for sale?? September 21, 2005, 1:06 am
