Bandwidths in an Optical System
Please i am a little confused about how the bandwidth of an optical system is calculated. The units involved are a little not standardized so it confuses me a lot . How much bandwidth does a 32nm window with a 50Ghz channel spacing have. Please I would be grateful for any explanation as to how this was calculated. Thanks
Deamon
Bandwidth is bandwidth. It's a bit confusing when everything else is in wavelength units--just write
nu = c/lambda
then differentiate to get d(nu)--i.e. the bandwidth:
d(nu) = -c d(lambda)/lambda**2.
Cheers
Phil Hobbs
Phil Hobbs
Bonsoir Deamon?,
The 50 GHz spacing gives about 0,4 nm spacing in DWDM 1550 nm. So, in the 32 nm window you can put 80 wavelengths. The global bandwidth is 80 x 50 Gbit/s =3D> 4 Tbit/s.
Best regards, Michelot
Michelot
